Hi,
I want to draw a line and bend it to create a curve, how do I do that? When I draw a line I'm unable to modify it.
Thanks,
Simon
How to bend a line
SimonSt
Sunsparkle
- Version de PhotoFiltre : 9.0.0
- Système d'exploitation : Windows ME
Re: How to bend a line
Hi SimonSt,
What kind of curved line are you looking for? Do you have an image example to work off? I've been wanting to do the same thing for a while, and had to figure out my own to do with photofiltre studio, but the lines curve quite a few times the way I set it up. I'll try to find an image to give you an idea of how it looks.
Sunsparkle
The lines in the background of this image are the ones that i've been working to create: -
http://i47.photobucket.com/albums/f159/ ... CS-845.jpg
~Sunsparkle~
~Sunsparkle~
Hi,
you can try :
- Menu Filter/Deform/Twirl
- Menu Filter/Plug-in/Deformation (which be downloaded from PF official web site)
For PF Studio version only :
- Deform tool /twirl, zoom in , expand or contract
- Menu Filter/Filter 8bf/MV's Plugins/Pinocchio
Look at this post :
http://translate.google.com/translate?h ... 64#p128964
you can try :
Look at this post :
