Not a valid Win32 application ?
mike5
Message par mike5 »
I've been using Photofilter for 2 years now, I just reloaded X.P. and DL'ed photofilter. When I try to look at a picture on my harddrive, I get "not a valid Win 32 application" . Before I could look at anything with no probs. The only way I can get a picture to work with Photofilter is to click and drag the picture into the Photofilter window. What did I do wrong here?
Any ideas?
thanks, Mike.
Check the application associated to the image format
For example, what application are used whan you double-clic on a jpeg file ?
you can use SHIFT+Right click on the image file and choose "open with" to change the application used
Hi mike,
have a look on the Downloads page of the site :
It is strongly recomanded to download the plug-in Association to associate images files format to
PhotoFiltre Studio (PFI, PFS, and other files format). Click here to display the plug-ins page.
If you place PF in Program files as stand alone, (without install), the registry can't link a picture file with the PF application. :wink:
mike5
Message par mike5 »
Antonio, the 1st thing I did was "change to open with PF " Tom, I've now DL'ed the entire plug in package. What do you mean if I place PF in Program files as stand alone?(without install) I think this is my prob. I've uninstalled many times now and can't seem to get it right.
Thanks guys.
PhotoFiltre.exe don't needs to be installed. For example, this file can be placed on a USB key and work.
On this page: http://photofiltre.free.fr/download_en.htm , the zip file is so built .
But for more convenience, the first link points on a classic setup file.
Indeed, this one is identified in the registry through the install process.
mike5
Message par mike5 »
Thanks for all your help guys! It seems I had 2 installs 1 was partial and didn't work right. I chose "open with" on the right one and now I double click on any pic. and it opens right away, now I have to figure out how to get rid of it opening without the shell around it.
Thanks again.
