PF 6.2.7 with network redirects
corelord
Version de PhotoFiltre : 7
Système d'exploitation : win/Linux
Processeur : many
Mémoire RAM : lots
Message par corelord »
I have selected PF 6.2.7 as the image maniupulator for my school. I am starting to put it out on machines. We have all of the users "My Documents" redirtected to the user's own network share. The users do not have the ability to write on the C-drive. I would like a way to make the preferences for open and save - go to "My Document" for all users. But iPF wants this to be a specific UNC ( \\servername\username\My Documents). Is this possible by using a special option in the Photofiltre configuration file on the local hard drive?
Thanks
No :cry:
but you can set manually the photofiltre.ini file and change the variables "open" and "save"
