Changing eye colour
tannie
Version de PhotoFiltre : Free and Studio 9
Changing eye colour
Message par tannie »
Is it possible with the studio version to change the colour from the eyes or only work this with PS?
I wanna make his eyes here blue! :)
http://i160.photobucket.com/albums/t172 ... 36/124.jpg
I don't know if your Play Station is able to do this ? :wink:
But no problem with PF6 or PFS, have a look at the adjust menu :
You can try "Replace color range" or "Hue variation" or "Hue/Saturation".
Indeed, you have to select the eyes before.
viewtopic.php?p=122104#122104
Jaume44
Système d'exploitation : w7
to blue
Message par Jaume44 »
Tannie,
You can do the following in Photofiltre Studio or in Photofiltre: the change-to-blue eyes below was accompished in PFS using the polygon select tool on the eyes*, and then simply adjusting the hue under "hue adjust." You could lighten the blue using the gamma adjust or the bright/contrast adjust or a combination of the two. In most instances, when selecting areas it is helpful to enlarge your "view." In this case I was at 800%. There are several ways to achieve this type of color change, but the "hue adjust" keeps the color blend true to the original hue's properties. Below are examples of blue, dark and light. I hope this has been helpful.
*When making multiple selections, after the initial selection you must hold down the control key while making additional selections, as here two eye areas.
Dernière modification par Jaume44 le 08 sept. 2007 17:11, modifié 1 fois.
Jaume44
Added note..... unless you absolutely need the eyes to be blue, you might consider a shade of green considering the brown tones of the overall image. Just a thought. The blue looks fine, I just noticed while going throught the hues that the green looked pretty good also.
tannie
Thx Tom and Jack for the infos!This is looking great Jack.I've try it and with this photo I had a bit problem,but with others it work great.Thx for the green eyes tip.
This is coming out with the one pic! :oops:
This with another one! :D
Hahaha Tom my Playstation is Photofiltre Studio! :wink:
Jaume44
Tannie.........
Viel Danke! You should be teaching me...these colors are great!
Jack
PFS is the best Play Station i know. :lol:
tannie
Jack you make me blush! :oops:
You're right Tom and easy too! :D
