Est-ce qu'il y un plug-in pour lire des Nikon D200 raw NEF files?
(je peux pas parler francais bien; s'il possible, repondez en anglais s'il vous plait. merci)
Nikon NEF files
maia cavelli
- Version de PhotoFiltre : 6.1.5
- Système d'exploitation : WIN XP
maia cavelli
Seb_31
- Système d'exploitation : XP
The plugin is here :
http://www.photofiltre-studio.com/plugi ... XnView.zip
To install the plugin, you just have to put the pfl file in the folder 'plugins' in 'C:\Program files\Photofiltre' where you should have instal photofiltre.
Have fun !
Have fun !
maia cavelli
Thanks for the directions.
I have since learned that one must first have the Studio edition of Photofiltre to utilize the NEF plug-in. I'm still working off the shareware version, so can't yet implement this solution. Will consider my alternatives now that I seem to have all the necessary info. Thanks, all.
ecolyx
Re: Nikon NEF files
I was recommended this program, so downloaded it and found it didn't work without a plugin for NEF files.
I got the plugin as per the instructions above, but now it gives an error when I start the prog saying libgfl211.dll was not found.
That is pretty shoddy! Can someone tell me how to get this program working with my very popular brand of camera, please?
Cheers.
Cheers.
Re: Nikon NEF files
Hi,
The information above is not complete.
The plugins page for PhotoFiltre freeware is there :
http://photofiltre.free.fr/plugins/plugins.php?lang=en
and full down you can find the "Additional Dll for the XnView's plugin" you need to extract and copy in C:/WINDOWS/system32 folder.
From nearly 4 years i daily work with PF6 or PFS, i can tell that every inner quality problem was solved when reported.
