Translation
Translation
Nederlands, Japanese, Danish, Vietnamese and Czech must be updated. If someone want to do this, here are the strings to translate (send me the result by e-mail)
Code : Tout sélectionner
// V1.9
TrLblSymmetry2 = 'Symmetry';
TrMnuPerspectiveCorrection = 'Perspective correction';
TrMnuHorizonCorrection = 'Horizon correction';
TrMnuCircularBlur = 'Circular blur';
TrLblDeltaX = 'Offset X';
TrLblDeltaY = 'Offset Y';
TrLblCursorBig = 'True size cursor for drawing';
TrLblLayerBounds = 'Show active layer bounds';
TrLblRawWB = 'Automatic white balance for RAW images';
TrLblDrawAlpha = 'Draw on Alpha transparency';
TrMnuExpTxtDir = 'Textures folder';
TrMnuUseTexture = 'Use as texture';
TrMnuMultiline = 'Display thumbnails in multiline'; // explorer
// not used for the moment
TrMnuFlattenImage = 'Flatten image';
TrLblSendMail = 'Send by electronic mail';
