Landscape
BEDO
Version de PhotoFiltre : 6
Système d'exploitation : XP2
Landscape
Message par BEDO »
Does anyone know, is it possible to make Portrait the default setting instead of Landscape?
At the moment I have to alter it each time in print setup.
Thanks in advanced.
no,
PF choose the best orientation (image size)
BEDO
Message par BEDO »
Thank you Antonio.
I rather thought that was the case, as I have spent some time looking for preferences to alter default settings, to no avail. But it is a small price to pay for an otherwise superb piece of software.
Thank you for your answer.
