Aspect ratio
BEDO
Version de PhotoFiltre : 6
Système d'exploitation : XP2
Aspect ratio
Message par BEDO »
I am delighted with PhotoFiltre I find it very easy to use.
However, one thing I would like to do is to be able to disable the aspect ratio when I use the print facility. I cannot find a check box to do this.
Hi Bedo
there is no way to disable the aspect ratio in the printing window.
But before to print, you can change the size of your image and uncheck the aspect ratio.
BEDO
Message par BEDO »
Tom a écrit :Hi Bedo
Hi Tom,
Thank you for your answer, I think I know what you mean ie resizeing the image but am a little confused when you say "uncheck the aspect ratio" as there is nowhere to uncheck, or have I missed the point?
Sorry if I'm being thick. :)
BEDO
Message par BEDO »
Hi Tom,
I was having a senior moment. I resized an image and then saw the Aspect ratio box to uncheck.
Thank you very much for the info.
Dernière modification par BEDO le 11 juil. 2007 23:47, modifié 1 fois.
:wink: good entertainment and pleasure with PhotoFiltre.
BEDO
Message par BEDO »
Hi Tom,
Clicked on your sig, Trad is one of my favourites, so you are right,
Thank you so much.
Take care.
