Blur and Smudge tools
Sunsparkle
Version de PhotoFiltre : 9.0.0
Système d'exploitation : Windows ME
Message par Sunsparkle »
Hi all,
I've been doing a lot of work on photofiltre studio recently trying to create my own images :oops: not getting very far with it, but thats besides the point lol. Just a suggestion but for the images im working on, I like to use the blur and smudge tools a lot but the "precise" setting on them is a bit to big for some of the detail I'm trying to work with, is it possible to make an "extra small" size for both of these?
Thnkx,
~Sunsparkle~
Hi,
have you tried Edit/Fade ? after application indeed. :)
Sunsparkle
Hi
Hi Tom,
thnkx for replying so quickly :) I have tried fading, but sometimes it doesn't look quite right afterwards and makes it a bit awkward, especially when I try to make images of people. :oops:
~Sunsparkle~
Sunsparkle
Re: Blur and Smudge tools
Please is it possible for this adaptation?Lately I've been needing a smaller blur tool and smudge tool quite frequently for college work, leisure and other bits and pieces.
Thanks
~Sunsparkle~
extra small" size
==> the small size use a 3 pixels radius, it's very small. I think smaller is don't need. Just decrease the pressure value :wink:
Sunsparkle
I know i've tried to use the pressure slider to change amount smudged, but it still seems bigger than 3 pixels. Anyway I'll take your word for it :) :D :) .
Thanks
~Sunsparkle~
Symphonie
Mémoire RAM : 2 Go
Message par Symphonie »
3 pixels radius, so it means 6 pixels diameter I think ;)
yes :wink:
Sunsparkle
Hi,
Thanks for all the replys. This is the image that I've been working on recently, and in some cases the smudge tool seemed just a little to big, this is why i made the request but thanks again anyway. Hope you like the image :oops: .
http://i47.photobucket.com/albums/f159/ ... obered.jpg
~Sunsparkle~
