Photofiltre 6.0.2
Beasly
Photofiltre 6.0.2
Message par Beasly »
I am running Photofiltre 6.0.2 on Windows ME and whenever I try to open Photofiltre there is a 30 second delay. I tried uninstalling and then reinstalling but it still has a delay of 30 seconds to open. I don't have any plugins installed for Photofiltre, and tried various settings in the preferences but I still have this 30 second delay. Photfiltre is the only application on my computer that has this delay.
Is there anything I can do to fix this delay with Photofiltre 6.0.2?
Beasly
Additional info: I just found out that if I open Photofiltre offline or when I'm not connected to the internet it opens fine, no delay. This delay only happens when I try to open Photofiltre when I'm online or when I'm connected to the internet. What could be causing this 30 second delay?
Check if you have a virus !!! PhotoFiltre don't connect to internet !!!
Beasly
Re:
Antonio a écrit :Check if you have a virus !!! PhotoFiltre don't connect to internet !!!
Hi Antonio,
I check for viruses and spyware on a daily basis.
I did however notice that when "spool32.exe" is disabled as a running process in Windows ME, this delay problem exists. I enabled spool32.exe and Photofiltre opens in about 2 seconds. If I am correct spool32.exe has to do with the printing process for Windows ME so why does it affect Photofiltre from opening :?:
<spool32.exe isa part of the Microsoft Windows Operating System which deals with the spooling of Microsoft Windows print jobs. This process is only executed when this method is selected in the printers configuration properties. This program is important for the stable and secure running of your computer and should not be terminated.>
