Plugin Contour to selection
Marga
Version de PhotoFiltre : PF and PFS
Système d'exploitation : W7
Mémoire RAM : 3
Message par Marga »
Hi all,
Can someone tell me HOW the plugin Contour to selection has to be handled... how it works?
Greetings from Holland,
Marga
This plugin is not needed because now PF6 and PFS have the magic wand tool
Hi Marga,
This plugin may only well work when the selection you have done is filled with a black color on a white background.
Use right clic in the selection and Stroke and fill.
The checkbox "Optimise the selection with level X" allows in fact to simplify the number of points of the vectorial selection.
This plugin can be usefull if you wish to work with Text 2 Path
Notice too :
to do a Search with the good button above and contour + selection as key, select International Category.
And you find for example the answers at the same question you did post : :)
viewtopic.php?t=2783
