How do you create new nozzles for Photofiltre? I've tried saving a picture file as a .png file with no results. Please help.
Thank you,
Paul
Making Nozzles
PayPaul
- Système d'exploitation : Windows XP Media Center
- Processeur : Athlon 64 X2
- Mémoire RAM : 2GB
Daysideria
- Version de PhotoFiltre : 9.0.0
- Mémoire RAM : 256
You can find your answer here (french) : http://www.photofiltregraphic.com/19bru ... zzles1.htm
If you don't understand french, follow my translation :
-choose a size for one nozzle (it must be a square with a white background, on which you stick your picture)
-create the second with the same size
-In edition, click on copier
-then you take the first nozzle, and (in edition), you go to collage spécial to click on assembler le collage à droite (the second nozzle will be stuck on the right of the first).
-Same thing for the following
-then, with the magic wand, you select the white background
-On Image (pull down menu), go on transparence automatique, and click on Région intérieure à la sélection
-on the same pull down menu, check RVBA
-save as .png file
I hope I've helped you
-save as .png file
PayPaul
- Mémoire RAM : 2GB
Nozzles: Plugin or addon
I've tried your tip for making them with mixed results. the first one I did is here and it is added to the nozzles drop down;
http://www.heisspiter.net/upload/110607 ... We_are.png
This one did not work. It was not added to the drop down list:
http://www.heisspiter.net/upload/110607 ... vasion.png
I hope the above linking works.
Perhaps there is a limitation on the number of nozzles?
Paul
Paul
Daysideria
- Mémoire RAM : 256
Retry Man
- Version de PhotoFiltre : PF STUDIO X
- Système d'exploitation : WİNDOWS10
- Processeur : İCORE5
- Mémoire RAM : 4GB
Re: Making Nozzles
bonjour, PF Studio uses maximum 100 nozzles in one session...
