I want to superimpose 2 faces of different pictures so BOTH are visible , the second one 'transparent' on top of the other.
How can I do that with version 6.1.1
Overlay
Hi Jack,
After paste and before validate, right click in the paste selection : Paste options : adjust opacity and possibly set a color for full transparency.
This can also be used to reply your last post :
- Paste the form selected on a united color (white, black, or any one else) different as the colors of your picture
- save your new picture
- when you wish tu use it again, select the background united color with the magic wand, invert selection and copy
- by this way you don't lose any color
- differently when using Image/Automatic transparency, your picture is automaticly converted in 256 colors, as a gif picture.
Notice also that a new release 6.2.7 is available on the PF web site.
