stopping autozoom when scrolling ...
pixiepet
Message par pixiepet »
Hi there,
I've recently installed PhotoFiltre on my new system, [windows XP]. For some reason, it autozooms when I'm scrolling. Is there any way to stop this? I didn't have this problem when using PhotoFiltre on my old system, [windows 98].
cheers ... ~P~
==> don't understand ? scrolling with scroll bars ?
Jaume44
Système d'exploitation : w7
Message par Jaume44 »
This happens with my setup sometimes, but it is my mouse and its software that causes it.
Check your mouse preferences and/or options.
:oops:
pixiepet
okay, let me clarify ... when I run the mouse over an image in photofiltre and then use the wheel to scroll up and down over the image, it autozooms in and out instead, which is really annoying. The scrollbar for the image works perfectly fine though.
My mouse operates perfectly well elsewhere, so I don't think the mouse can be the problem.
the autozoom occurs if you click the mouse wheel, not with wheel up or down
pixiepet
no, it occurs just from rolling the wheel up and down ...
Have you tried that? :
Tools > Preferences > Start up -> disable zoom with mouse track ball
==> never seen this bug, i think your mouse is too sensitive :oops:
pixiepet
"Have you tried that? :
Tools > Preferences > Start up -> disable zoom with mouse track ball"
yeah, I'd already tried that and while it does stop the autozooming, it also stops any scrolling over the image. Which means I can only scroll using the scrollbar - and while that's not earth-shatteringly awful, it is irritating.
I've even tried uninstalling Photofiltre and then reinstalling it ... but with no effect.
:roll:
