* Make the Open file window resizable, not fixed. When browsing 100+ images, the small size makes for slow going.
* Add a progress indicator for when a filter is being applied. I thought the program had locked up at first!
* Add an additional way to scroll an image other than the scroll bars. Right-mouse hold and drag would be great.
* Zoom levels of 120% and 150%. Going immediately from 100% to 200% is too big of a jump.
* Allow the tools palette to be docked on the left. Make it easier for left-handed users
* Allow the background layer to be made invisible.
* Make the stroke width on the Text tool adjustable.
* Once registered - hide the Registration menu item under Help.
* Allow pasting a copied image into the current layer. Paste
* Add a toolbar button for Rotate free or even better, make the toolbar customizable
* A button/keystorke that allows you to shift into selection mode without having to first uncheck Stroke and Fill
* Support for gradient fills, not just gradients loaded from patterns
* Ability to adjust the Kern (horizontal spacing between letters) of text
* Vertical text support
I know that it's quite a list of features, but I just bought the program and hope to see it get even more useful!
[/list]
