Printing problems
gerard.boterman
Printing problems
Message par gerard.boterman »
Few questions about printing:
Wanting to repeat exact printing to a label postion,
a) How can we set the default values for printing, e.g. portrait, untick center, tick original, enter X and Y values.
These reset every time after printing.
b) The actual values X,Y of distances to the edge of paper are not correct / need adjusting. Cannot find this option for offset adjustments, so X and Y represent correct cm.
==> not possible, reset for eatch image
==> yes it's correct, it's because your printer add no removable margin (some printers add 0.5 cm)
gerard.boterman
Thank you for your reply.
May I suggest to add an option to save printing settings for a next release of PhotoFiltre please?
Great program! Cheers, Gerard
