rotate text 45*
huh
rotate text 45*
Message par huh »
hi i'm trying to do a diagonal text from bottom left to top right.
using PF 6.x.x
any tips? i got the text 2-something plugin but can't seem to be able to add any additional shapes (i.e straight line) to the list of options.
thx :oops:
Benthai
Message par Benthai »
Hi Huh...
In the text tool you write your text and at the right side of the "multiple choice text positions"you'll find an "angle" box in there you put the following value:-45 then press ok and normally your text should be as you wished ..
Good luck
Benthai
huh
Message par huh »
oh gees that was really easy...
thanks champ
GrimFinger
Processeur : 3 Ghz
Mémoire RAM : 512 Meg RAM
Re: rotate text 45*
Message par GrimFinger »
I got this plug-in to work in the free version of Photofiltre, but is there a version of it that works with Photofiltre Studio 9.1.0? I tried putting the plug in in the plug in folder, but it still doesn't seem to work.
Also, is there a way to unselect the paths like the arrow path?
Is the arrow path one of the ""multiple choice text positions?" I look for that text, but don't see it.
Is there also a way to use the stroke function with the text-2-something plug in? Finally, is there a way to increase the size of the stroke function?
I've used Photofiltre free version for a long while. It's a shame that the standard text feature is so limited.
