The right way to install pluings
latintrans
Message par latintrans »
Could somebody tell please the right way to install plugins for photofiltre 6.2.7, i have tried to install them in the plug ins folder of photofiltre but it sems not work, if there is a tutorial to install plug ins please point me out
Hi,
why simply do when it can be complicated ? :)
You can find a post-it on top of this proper forum to install automaticaly all or only the plugins you want to choose.
elkejelleke
plugin
Message par elkejelleke »
I have a problem to...
I al ready have e-mailed but I'll ask it here to:
I installed severals plugins and unzipped them in "plugin(s)" (I don't remeber of it was with an s on too ;))
And then I open PhotoFiltre but there are no plugins
(I do have click by preferences that when de program starts the plugins will be loaded...)
can please somebody help me?
Ellen
viewforum.php?f=16
and look at the first post-it.
So you don't need to know the right folder name for your plugins.
When the plugins are loaded, you can verify that they are present in Preferences at Plugins bar.
Don't forget to check Plugin's bar in View menu.
