Photomasques in Photofiltre do the same as overlays in PSP? I mean: apply photomaskes i´ll have the same effect? If someone knows this, please answer me.
A little question
claudya07
- Version de PhotoFiltre : Studio 9.1
- Processeur : pentium4
- Mémoire RAM : 1 GB
A little question
Hi.
claudya07
Thanks
Tom:
Thanks for the answer. What i can see is that the photomasks are black and white, and the overlays could be colored. Is there a way to have colored photomasks? Hugs.
claudya07
Thanks
Thanks Tom! I´ll follow your tip, and take a look at the file. Hugs.
