Dear Friends,
I was wondering if would it be possible to get Photofiltre as a stand-alone application to use on a usb flash disk without installation.
Thank you
Standalone app
lillo
Yes it is.
PhotoFiltre is a standalone application which does not need any installation.
You should download the french zip version and the language file you prefer, from this page :
http://photofiltre.free.fr/download_en.htm
You need to unzip the language file in the same directory as PhotoFiltre.exe was unzipped too, and PF works fine from an USB 2.0 Key.
