Text Insertion
Verdeboy
Text Insertion
Message par Verdeboy »
I have to insert a lot of text for my CD insert. I need to have some bolded, some italicized, and I need to vary the point size and the font in several places, for example:
1. Of Horses and Dreams 3:17
It seems like I have to have a separate layer for each point size, for each font, for bold, for italic. This means I'll have about 50 layers alone just for my CD tray insert.
Is there a way to do all this in one layer like I am doing now?
==> no :cry:
Hi Verdeboy,
First you could merge the layers of the same line of text.
But i prefer use an external text editor, like MS Word or OpenOffice.
When the entry is done, you turn your screen in the best resolution and you do a print screen,
open PFS and paste as new image.
I had justly to do the same job last year :
http://nopreachersjazz.free.fr/FR/Album_2.html
The printer workshop has made very correctly 3 pages of text edited with this process. :wink:
