Submitting a layered file to the print shop.
Verdeboy
Message par Verdeboy »
I was wondering if there's any way of saving a multi-layered file in a form that can be opened up by photoshop. My print shop only deals with photoshop and they must have a layered document. I told them I could give them separate 32 bit tiff files for each layer, but they want all the layers to be in 1 file. What can I do? I don't want to have to start all over in Photoshop and I don't have the patience to learn another program. :cry:
no compatibilty with PSD or PSP files :cry:
freddy26
Re: Submitting a layered file to the print shop.
Message par freddy26 »
Hello everyone,
Use PSD or Save As & delete all the hidden file which is not in use. So that it will help to run without any error.
I just know this solution but if any other solution you have please share.
Thanks in Advance...
TinyAlien
Version de PhotoFiltre : 7.2.1
Processeur : Pentium D
Mémoire RAM : 3Gb
Message par TinyAlien »
Why do they need a layered document exactly?
