Separate Layer For Background Color Only
Verdeboy
Message par Verdeboy »
Hello,
I am trying out the Studio version and am having trouble creating a separate background layer of color for my CD template. I can open a new layer of color, but it takes on the size of the whole template file, which is 8.5 x 11 inches. I don't know how to shrink this layer of color down to just the size I need for the CD template - 6.15 in x 4.88 in.
Conversely, I can use the magic wand to fill the correct area of the template background, but I don't know how to make this into a separate layer.
Thanks,
Re: Separate Layer For Background Color Only
Verdeboy a écrit :... I can open a new layer of color, but it takes on the size of the whole template file, which is 8.5 x 11 inches. I don't know how to shrink this layer of color down to just the size I need for the CD template - 6.15 in x 4.88 in. ...
No, a layer of color works only for the whole size of the image
Verdeboy a écrit :... Conversely, I can use the magic wand to fill the correct area of the template background, but I don't know how to make this into a separate layer...
Yes it's the good way, just a right clic in the selection of the magic wand and Duplicate.
Verdeboy
Worked like a charm. :)
Merci beaucoup mon ami.
