Layers
jcfreak63
Version de PhotoFiltre : PhotoFiltre 6
Layers
Message par jcfreak63 »
I can't seem to find the individual layers for any pics. How do you get them to be visible?
Thanks.
I don't understand your problem :cry:
What is your PhotoFiltre version ?
jcfreak63
I use Version 6.2.7 It's my understanding that there are supposed to be individual layers like in Photoshop but I can't seem to find them anywhere on the workspace. Is there a keyboard shortcut or something I'm missing. I just started using the program so I'm a complete newbie and haven't discovered where everything is yet.
Jepe
Version de PhotoFiltre : PF 6.4.0 & PFS X 10.3.0 beta
Système d'exploitation : XP SP3
Processeur : AMD Sempron 3100
Mémoire RAM : 1536 Mo
Message par Jepe »
Hello,
Layers are only available in PhotoFiltre Studio (shareware as Photoshop) and not in the freeware version (6.2.7).
Jean-Paul
Heis Spiter
Mémoire RAM : 1536 Mo DDR
Message par Heis Spiter »
Jepe a écrit :Layers are only available in PhotoFiltre Studio (shareware as Photoshop).
But cheaper than PhotoShop ;).
