A plugin for assisted white balance. beta
Alain
Mémoire RAM : 1024
Message par Alain »
Hi
I've made a plugin that can correct the whitebalance. Just use the pipet on some places that should be white (or grey) and then use one of the five preview buttons.
All remarks are welcome. Be aware that this is beta software 8)
Download :
EDIT : There's now a 0.95 on :
http://users.telenet.be/alain.decamps/wbalance_95.zip
Alain
Dernière modification par Alain le 30 août 2005 23:14, modifié 4 fois.
pf
Message par pf »
Hi,
First, sorry for my english .... :oops:
Welcome to PhotoFiltre plugins' developpers.
What is your programmers' language ??? (C?)
Your plugin run fine, no bug, no crash.
1) When PhotoFiltre is hide, the plugin stay "on top"
2) When no color is selected, its good if the actions buttons was disabled.
3) Perhaps a slider to set intensity, in future ?? :wink:
Congratulation, as for the next ????? :wink: :D
p@f
Alain
Mémoire RAM : 1024
Message par Alain »
pf a écrit :Hi,
p@f
Started with democ from the sdk. Will move to c++, but with the free commandline c++ compiler from Borland.
3) While the intensity depends on the chosen preview, it may be a good idea to add an extra slider in the future.
Alain
Bill
Version de PhotoFiltre : Free and Studio
Système d'exploitation : Coffee
Processeur : God Given Brain
Mémoire RAM : Not as well as when I was younger
Before and After
Message par Bill »
Alain:
Here's a result from a quick test of your plugin. I did fade the filter a little but otherwise did a great job I think.
The few images I worked on I was pleased with it over using the Invert Color Layers method because it doesn't wash out the hi-lites areas as much as that method.
Good Job and thanks for sharing.
Wow 8)
The result is impressing :D
Alain
Mémoire RAM : 1024
Re: Before and After
Message par Alain »
Bill a écrit :Alain:
Thanks for the nice comment and the example. Did you try the different previews? Any comments on that...
Alain
Bill
All worked fine.
Message par Bill »
Alain:
Everything seemed to work fine for me. I'll probably do a quick tutorial or the above image change using your plug-in.
Alain
Mémoire RAM : 1024
Re: All worked fine.
Message par Alain »
Bill
That would be great.
Alain
Alain
Mémoire RAM : 1024
Message par Alain »
Hi
Here a new beta version 0.91, a lot of internal changes. I've tried to integrate most requests. The algorithm itself hasn't changed.
http://users.telenet.be/alain.decamps/wbalance_91.zip
Alain
Bill
Looking Good!
Message par Bill »
Alain:
All works fine for me. Here's the changes I noticed.
1) No buttons except Cancel are active until you pick a color.
2) Once a color is selected Color Preview buttons become active.
3) Once a Color Preview button is selected the Restore and Okay buttons become active.
There is one thing I did notice though that I'm not sure if you can do anything about:
If I select your Plug-in and then select the Zoom Tool tomget a better color sampling your plugin goes to the rear and I have to shrink the window to find it.
Alain
Mémoire RAM : 1024
Re: Looking Good!
Message par Alain »
That should ideed be the visual changes. The last one is known to me and I will try to fix it. Before the plugin would always stay on top, even if you started another application.
Alain
Alain
Mémoire RAM : 1024
Re: Looking Good!
Message par Alain »
Hi
Here a new beta version 0.92, should fix the disappearing :
http://users.telenet.be/alain.decamps/wbalance_92.zip
Alain
Bill
Talk about Service
Message par Bill »
Alain:
Boy was that quick :D
Works like a charm.
Again thanks for sharing with us.
JogyGeorge
Version de PhotoFiltre : 6.2.0
Processeur : 2.4Ghz
Mémoire RAM : 256
Message par JogyGeorge »
Nice ... :) Really makes my photos look a lot better now! .... Thanks!
A little request: Would it be possible to have one more button called "Original". Yes, I know the restore sets things back and I can see the original, but the problem here is that all the pixels I selected get lost and I'll have to re-select them again. It is sometimes useful to Preview Red and compare it with the Original as also similar comparisons of Blue and Green with the Original. Now, I could compare between colours, but not with the original as the pixels selected are lost.
Also, Is there some definite no. of pixels that "WB" uses ... I mean like 1 to 10 or 1 to 20 or something like that or does it calculates based on all the pixels selected without limits? Does the selection of the say coloured pixel more no. of times change the average?
Thanks for the plugin and Cheers!
Alain
Mémoire RAM : 1024
Message par Alain »
JogyGeorge a écrit :Nice ... :) Really makes my photos look a lot better now! .... Thanks!
I see you're point.
JogyGeorge a écrit :Also, Is there some definite no. of pixels that "WB" uses ... I mean like 1 to 10 or 1 to 20 or something like that or does it calculates based on all the pixels selected without limits? Does the selection of the say coloured pixel more no. of times change the average?
The plugin uses the average from the last 10 selected points or all points if less than 10. If you select coloured pixels they are taken into account, this can give some special effects. The plugin assumes that all selected pixels should have been grey (aka should have the same amount Red,Green and Blue) and calculates the correction whats needed to make them "grey". This correction is then applied to all pixels.
Maybe a good idea to ignore selected pixels if they should need a much higher correction that the other selected pixels. This would make the plugin more "error safe".
Alain[/quote]
