question sur les propriétés d'un image ou photo
35neutral
Message par 35neutral »
Comment peux-je conserver les propriétés d'image (la date et l'heur de la photo) en redimensionnant ou éditant l'image ? Merci bien
When resizing or otherwise editing a digital picture, how can I preserve the original properties embedded in the image, such as date and time?
Thank you much.
Jason in Oregon
Hi Jason,
Images properties are also named or abstracted as Exif datas ( even though they contain IPTC datas).
These properties can be red an exported from menu File / Image properties.
They can be preserved only for some file as jpeg, and you have to specify it in menu Tools / Preferences / Saving
When you save a jpeg picture, in the dialog box, you can also check or uncheck : Preserve EXIF/IPTC data.
Have a nice day in Oregon. :) Au plaisir de te lire prochainement.
