Night-Fog-Banner (Level: Easy + My First Tut)
You need help to start ? Or to use a plugin ? Use the tutorials ! / Ĉu vi bezonas helpon por starti ? Aŭ por uzi etendadon ? Usu la Didaktikojn !
LilSushi
Message par LilSushi »
Heehee. I'm LilSushi and this is my first tut. :mrgreen: I did this with normal Photofiltre. Not Photofiltre Studio.
[Tutorial Level:] [Easy]
Learn to make that. Sooo easy, sooo simple.
1. New image. Pick your size.
2. Filter>Visual Effect>Fog>Black. (I did it 2 times)
3. Gradient. Monochromatic. Bottom to Top. Color 1, White, 100%
4. Edit>Stroke and Fill>White, Lines>Opacity 10%
5. Add Text.
6. Filter>Color>Night Effect.
Result;
And for a red effect you can do Filter>Color>Sunset Effect.
Sunsparkle
Version de PhotoFiltre : 9.0.0
Système d'exploitation : Windows ME
Cool
Message par Sunsparkle »
Cool LilSushi! thanks for this tuto :)
[Tom] Thanks to consider the size defined in Annonces for signatures : 468 x 60 [/Tom]
LilSushi
Re: Cool
Sunsparkle a écrit :Cool LilSushi! thanks for this tuto :)
You're welcome.
I don't know what Tom means I read that but it's in another langauge how should I know what it means & it's a BANNER not a signature :roll:
Hi LilSushi,
my remark concerns Sunsparkle : his signature is too big.
I have unchecked his display.
She would be so kind as to consider the Annonces :
viewtopic.php?t=11805
Sunsparkle
Sorry
Sorry Tom I hadn't realised, I will get to work on makin them smaller or maybe make some new ones lol. Thanks again for the tuto LilSushi :)
~Sunsparkle~
