Opacity brush
You need help to start ? Or to use a plugin ? Use the tutorials ! / Ĉu vi bezonas helpon por starti ? Aŭ por uzi etendadon ? Usu la Didaktikojn !
JKoD
Opacity brush
Message par JKoD »
Hey
how do I make my brush opacity?
Hi JKoD,
Can you give more explication about your question ?
I don't see which tool you want tu use with, or what effect you want realise.
JKoD
Message par JKoD »
I want to make my (paint)brush more see-through, so it not is 100% that color you paint with that will cover my picture. If you understand what I mean..
- JKoD :wink:
Yes i see, :)
Preliminary opacity level of the paintbrush tool is only available in the shareware Studio version :
http://www.photofiltre-studio.com/
In the freeware version, you can only fade each action of the paintbrush :
menu Edit / Fade, or shift+ctrl+Z, then Tab and adjust with page-up or page-down key.
JKoD
Message par JKoD »
Ok, thanks
