new filters
jimclatfelter
Système d'exploitation : Windows Vista
Processeur : AMD Athlon X2
new filters
Message par jimclatfelter »
The new Artistic filters on the latest beta are wonderful. They create some great effects. I like all the new adjustment sliders. Great work! Thank you, Antonio.
I have one suggestion. I'd like to see a slider on the 3D Frames so that we can set the size (and transparency) in pixels as can in the Simple frame. The 3D frames we have are very nice, but it would be good to be able to set them wider sometimes. You may be working on this already.
The new Dust Reduction is great too.
Yes, i will review all filers and add parameters if needed. I will do that next months. Until jun, i will review my code and not add new functions for the moment :wink:
