Batch Layer request
RussButler
Version de PhotoFiltre : pfs 8.0.1
Système d'exploitation : Windoze
Batch Layer request
Message par RussButler »
First, I LOVE pfstudio. It is a great program! (As an ex programmer I really appreciate it).
I use it primarily to edit photo scans & find the batch tool very useful.
The batch filter layer tool would be extremely useful to me if a "difference" option was added. That way I could subtract out my film base color cast. The present normal/blending doesn't allow that afaik.
Thanks in advance for any and all replies,
Russ :D
I don't understand exacrelly what you want :cry:
The Blending mode "difference" exists in PFS...
RussButler
Yes, but how does one do take difference in Tools/Automate-Batch mode?
not possible, the automat batch only works with flat image (one layer)
