How to make this star?
alex07
Message par alex07 »
Hi! I want to know, how to make this star here.
Hi Alex,
look at this topic :
viewtopic.php?p=66404
You can get an automatic english translation by pasting this request before the original http adress :
Code : Tout sélectionner
http://translate.google.com/translate?hl=en&sl=fr&u=
like this way :
http://translate.google.com/translate?h ... hp?p=66404
alex07
thank you for the link. but why can i dont make the srars itself with photofiltre? the star i put in isn't in your list. how can i change the size and the color of these stars?
Yes, if you want, you can do your own star, but that's not a beginner task, cause you need to know how create a mask, with gradient and transparency.
To start quickly, you have better to read the PhotoMasque.html page which is in the PhotoFiltre folder.
Other way : open menu ? Information or F1 key, go to PhotoMasque module and "To learn some more about this module" click here.
You can see how to apply any colour you wish. The size is dependig of the selection you draw before calling the PhotoMasque module.
But i think you would read again the subject in link above. :wink:
alex07
Hmmm....but is there no easier way to make these stars? Have you got a instruction for me, how you made the stars? I already read the PhotoMasque.html, but after reading it I was none the wiser then before. :(
All right,
1°) the answer is in the subject linked :)
2°) practice it and perhaps we will be able to tell more :wink:
alex07
Do you mean with the subject link this here? viewtopic.php?p=66404
If so, there is no construction how i can do it. :roll:
In ten minutes with PhotoMasque :
alex07
This looks very good. Can u make a easy construction with pictures for me?
You can get this technique in a very short time, but you have to try it.
alex07
i would try it, but i dont know how to begin this :(
alex07
Thx....but which mask must i take to make these stars?
You winn, i'm dead. :)
