Getting windows to automatically use photofiltre
daveDownUnder
Message par daveDownUnder »
I found photofiltre completely by accident and really like it.
However, I am trying to set up my computer so that photofiltre automatically starts when I double click on a jpeg picture.
I have changed the file options settings, and now photofiltre starts but fails to correctly load the picture I have clicked on.
The error that comes up says:
Unable to load image "C:\Documents"!
then when i click OK the next error is
Unable to load image "and"!
followed by
Unable to load image "Settings"!
and so on.
I understand that the problem is that photofiltre is seeing the directory as a collection of parameters rather than as a single parameter. However, I do not know how to fix it.
Currently, in my folder options for jpeg file type, I have...
Application to use...
"C:\Program Files\Photofiltre\photofiltre.exe" %1
I know I need to change %1 but what do I change it to?
daveDownUnder
Oh lordy I figured it out. I tried to work this out myself but didn't think of the solution until after I made my post.
I must use quotes around %1, as in "%1". Now it works fine, and I am happy.
Hi,
very painful work indeed under windows by that way.
On the official web site, you can find a plugin to associate image formats with PhotoFiltre : Association
http://www.photofiltre.com/
