part of my face becomes grey
yava
Message par yava »
Who can help me
When I try to print a photo,it becomes grey in some parts of my face
Is this a printersettings errror or is this a error from this program. And is there a possiblity to change this.I got it only on 1 photo. The other pictures are fine.
Hi yava,
Impossible to give you a correct answer with too few indications.
If you post a link to this picture we can try to resolve this question.
Other way to try by yourself : if you install a virtual printer like PDFCreator :
http://www.pdfforge.org/products/pdfcreator
you can try to print without spend ink and paper, and verify if the colors are correctly saved in the pdf file as result.
