Saturation Mode ?
jimclatfelter
Système d'exploitation : Windows Vista
Processeur : AMD Athlon X2
Saturation Mode ?
Message par jimclatfelter »
I believe that the Saturation blending mode in PFS is not really Saturation mode. It seems to be identical to Overlay mode. When you blend an image with a duplicate of itself in Saturation mode, nothing at all should change, since the saturation is the same on both layers. But PFS Saturation mode changes the image in the same way that Overlay mode does.
no, it's not an overlay but a conversion error RGB <==> HSL. I use fast conversion algorithm for speed but this algorithm create some rounding conversion errors :oops:
jimclatfelter
HSLto RGB
It seems like more than rounding errors. Hue mode works perfectly. Why should saturation be so off? A blend of an image with itself in Saturation mode should make no difference. Instead we get an extreme difference. This can't be Saturation mode.
Ok, i will check my code...
It's a bug, fixed in the beta :
viewtopic.php?t=11103
jimclatfelter
beta
Thanks, Antonio. Can anyone download the beta? I can wait for the next release. But if I can get it now, I will. I don't know French, so I don't know what's on the beta 8.02 page.
Heis Spiter
Mémoire RAM : 1536 Mo DDR
Message par Heis Spiter »
Direct link to the beta version : http://www.photofiltre-studio.com/tmp/pfs810.zip
jimclatfelter
got it
Thanks, Heis. I got it installed.
Jim
