My photomanipulation with Photofiltre
Spappara
Message par Spappara »
isa32
Version de PhotoFiltre : Studio 8
Message par isa32 »
:( Je comprends pas un seul mot d'Anglais,
mais les photomontages sont réussis !! :clap:
Spappara
isa32 a écrit : :( Je comprends pas un seul mot d'Anglais,
I don't speak French, could you write in English please?? :oops:
Welcome Spappara!
Excellent artwork pictures! Can you give us some explanations about your technic?
isa32
Message par isa32 »
:( I do not include/understand only one English word,
but the photomontages are successful! :clap: !
translated by Google, I do not know the English!!
PhilippeB
Processeur : AMD 1700+
Mémoire RAM : 768 Mo
Message par PhilippeB »
Welcome Spappara,
Great :clap: except maybe your last attempt: too much morbid for me !
Regards,
Spappara
Corwin13 a écrit :Welcome Spappara!
First of all you must find a good pattern, I ofter use Pattern from http://angelrat-stock.deviantart.com/ (give credit).
I select the part I want change, select "imagezone", and use mode ->pattern -> Fill Pattern, and play with the different opacity (you can check it with the preview), press ok.
After all you arrange contrast/Brightness/saturation/color balance and fix the edge with a meticulous work of shading (soften or blur).
Sorry for my English, I hope you can understand me! :roll:
Spappara
PhilippeB a écrit :Welcome Spappara,
Regards,
Thank you! :D
Benthai
Message par Benthai »
Hi Spappara..
Welcome in here...
I had a look at the pictures you shew us...very well done...even if it is not the kind of style I like...Anyway I can recognize a good job and this one of it..
Thanks for sharing..
Benthai
Dernière modification par Benthai le 12 déc. 2006 13:19, modifié 1 fois.
Spappara
Benthai a écrit :Hi Spappara..
Welcome in here...
I had a look at the pictures you shew us...very well done...even if it is the kind of style I like...Anyway I can recognize a good job and this one of it..
Benthai
:D
Message par Coraliecaramel »
Very beautiful
:shock: :D
Est-ce que l'un d'entre vous veut bien traduire les explications?
merci :oops:
pix family
Processeur : athlon 4600
Mémoire RAM : 4GO
Message par pix family »
traduction a la va vite:
D'abord de tous vous devez trouver un bon modèle, modèle d'utilisation d'ofter d'I de http://angelrat-stock.deviantart.com/ (crédit d'élasticité). Je choisis la pièce que je veux le changement, le « imagezone » choisi, et le mode d'utilisation - >pattern - > modèle de suffisance, et le jeu avec l'opacité différente (vous pouvez la vérifier avec la prévision), serrent bien. Après que tous vous s'chargent du contraste/de équilibre d'éclat/saturation/couleur et fixent le bord avec un travail méticuleux d'ombrager (se ramollir ou tache floue). Désolé pour mon anglais, j'espère que vous pouvez me comprendre
I ia much will spappara me. very good work that makes me think has a “Gothic” film of horror, do not take it badly, it right my “is felt”
Welcome on PF forum Spappara :wink:
Very nice work , i love it :clap: :wink:
