Barrel and Pin Cushion effect plug in
weezer
Version de PhotoFiltre : 6.2.4
Message par weezer »
I am looking for a Plug-in to rectify Barrel and Pin cushion effect when using wide angle or zoom lenses. I see there is one on the main web site, but this is mainly for a Fish Eye lens correction, I'm not sure if this would be OK for what I need?
Does anyone know of something I can download and then upload into PF, or is there something already in PF that I have missed.
I found this on Dpreview, it says its for Photoshop, but would it integrate into PF OK. :?:
http://www.dpreview.com/learn/?/Image_T ... ion_01.htm
Hi weezer,
I'm suprised of your question. :roll:
Why the Fish Eye lens correction couldn't be convenient to your demand ?
Why didn't you try it on a duplicata ?
To appreciate the results of preview effect, you can do View/ Show grid.
The size of the squares can be defined in Preferences of PF6
Notice also that, in the plugin window, you can enter negatives values.
You can see also in a selection : right clic Transformation/Distort
weezer
OK I will give this a try and see.
Jaume44
Système d'exploitation : w7
Message par Jaume44 »
Here is a link for a plugin that suits the criteria given, however it is 8bf, useable with PhotoFiltre Studio. http://www.photo-plugins.com/index.php? ... &Itemid=43 You could also use this with Adobe software.
