Hello,
since yesterday i would like to test photofiltre(8.02), but the first thing i wanted to test .. failed.
I would like to scann an 2400dpi image, it is very old an i need the high resolution, but photofiltre stopped working.
At the first time i waited 5 minutes o kick it and the second i waited 10 minutes but only the CPUworked on 99,9% and no image on screen.
at the 3rd time, i changed to 600dpi and it worked.
So far i use also Pixel, and there was no problem with 2400dpi and the same picture.
So my software-& hardware details: amd64, win2000, acer s2w 3300U scanner with mirascan 4.03 (twain-software from acer/benq).
Is there a solve or a trick?
thank you,
gafi
scanner problem with 8.02
gafi
gafi
another problem with big files
So meanwhile i found also a problem, to open big tiff-files. 2400dpi with tiff/lzw-format i cannot openthe pictures. photofiltre stopped working and i must close the program with taskmanager. So is this a general problem? Did someone have also problems like me?
ciau gafi
ciau gafi
- Mémoire RAM : 12 Go
gafi
Thank you for quick answers,
I have 2gig RAM at home, but today i realized, that sometimes some programs work with this high resolution. Don't know at the moment why it workes sometimes .. and mostly not.. maybe i need a better scanner? and more RAM?Corwin13 a écrit :Hi, gafi!
How much RAM have you?
So the next two days i'm ill so cannot test it, with my computer at work.
So is there a great problem with more than 10.000 pixels? and will it be supported in the future or is it to complex? So actually i'm impressed by some nice features from photofiltre.Antonio a écrit :2400 dpi create big image (more than 10000 pixels !!!!). PF don't support this
gafi
Hihi.. ok 10.000 x 10.000 is a little bit heavy .o) Some of the pictures are very small, so i i wanna print them to A4 i need something more than 600dpi.Tom a écrit :Hi gafi,
Antonio wanted to say 10.000 pixels in both sizes : 10.000 x 10.000.
If my count is correct, it does 100 million pixels.
So you can print a poster 139 inches x 139. Fine for a loft ?
Himay19
Re: scanner problem with 8.02
Hello guys...
I have an issue with my new scanner "Standard CanoScan LiDE220 Color Image Scanner" when I checking my records, So please suggest me something about it.?
Thank you in advance...
first, ensure the source is correctelly set (menu File > Importation twain > Source)
