The image with the words, "Love Note," was made using my rose nozzel below with little pressure for the background.
The letter fill is from the gold pattern below.
The odds on the side are flowers captured online,
and later cut-out to form the collage they now are using the tranparent fade feature of Studio, set left to right.
The writing was in light grey, then selected with the selection wand, and filled with my India Gold pattern. Because the area of the grey varies, the fill is uneven giving it an antique feeling. The font is Curlz. Thank you very much. It is wonderful to have feedback, especially positive.
I will edit, but my question is, Link #1 for which, and where, Image Shack? Thanks.......waiting to edit properly.
PS I have just installed the Image Shack Toolbar, and I am not quite familiar with certain of its features. Previously I have resized or whatever was necessary........
[Tom] Indeed, you have to choose Link #1 in Image Shack.
Edit is done, i have put the good link, cause the 2 last pictures were unvisible
Before validate, you can try preview [/Tom]
