P.S. I forgot, I always run my Antivirus Program Scan on anything I download before installing, and then on the program file itself after. You probably already do this, but it is a good idea for those who do not.
Standalone Plugin Freeware
Jaume44
- Version de PhotoFiltre : Studio 10
- Système d'exploitation : w7
- Processeur : Pentium (R) Dual Core
- Mémoire RAM : 4 GB
Hey guys! You're going to like NiGulp 1.5 at http://www.sigmapi-design.com/freeware.htm. When you have made an image in PF or PFS, and you wish to fiddle with it using your plugins, but you have closed PF or PFS, open NiGulp. You may use the plugins from this program and save as separate images if need be. It by no means is a replacement of PF or PFS, but it is a very useful auxilliary tool. As for the freeware morphing software on this same page, I am downloading that now to test fly later.
