application start
B.R. Steenbergen
application start
Message par B.R. Steenbergen »
When I start PhotoFiltre I get the following message: 'libglf211.dll not found. Reinstalling the application may fix the problerm'.
I did so, but the bug wasn't fixed. When I click the 'OK' button, the program starts. How do I fix the problem?
Hi,
You can do a little Search with the good eponymous button above this page and use libgfl211 + dll as key,
select "International" as Category, check "Only display reference topics" and you get the right answer in english language :
viewtopic.php?t=1526
enjoy with PhotoFiltre, and have a beautiful day. :)
