Hello everyone,
I've used the search and found some threads dealing with transparency and semi-transparency. However, I still don't understand how to make a semi-transparent image from scratch. Let's say I have a (non-tranparent, of course) JPEG image. Now can somebody please explain, step by step, what I have to do to create a semi-transparent PNG from it?
Thanks in advance!
n.b.: I always use the most current release of PhotoFiltre Studio.
How to create a true semi-transparent PNG image?
PIGSgrame
- Version de PhotoFiltre : Studio 9.2.2
- Système d'exploitation : WinXP Pro SP3
- Processeur : P4 2,66 GHz
- Mémoire RAM : 512 MB
Jaume44
- Version de PhotoFiltre : Studio 10
- Système d'exploitation : w7
- Processeur : Pentium (R) Dual Core
- Mémoire RAM : 4 GB
Semi-transparent
Hi, please teach me what constitutes semi-transparent, and maybe I know? I know if you "export" a layer under "LAYER," you have the option of saving as a .png. If semi-transparent is simply a matter of saving it partially transparent using the opacity slide under the layer option before exporting, then that is what you do, but please, teach me. Thanks!
Jack
Jack
Jaume44
Tried
OK, I tried the above, exporting a transparency layer at 40% opaque, but when I inserted the .png saved layer, it was at 100% visible. The I looked at the transparency I saved by exporting it, and it also saved at 100%. Perhaps something here is of help. I am sorry I could not supply something more definitive.
Jaume44
Del Erase
Thank you Antonio. What constitutes "semi-transparent?"
I have executed the procedure, and it is really nice. Of course the semi part of transparency is self-explanatory now, after having executed and viewed it.
PIGSgrame
Now this is really neat. Below I followed the instructions provided by Antonio da Cruz, but instead of deleting the entire selection, I only deleted the white area of the text baloon. This is really a nice feature. See how the text remained 100% while the white is 50% in my SEMI-TRANSPARENT LAYER.
PIGSgrame
PIGSgrame
