Metallic Text => PFSTudio
You need help to start ? Or to use a plugin ? Use the tutorials ! / Ĉu vi bezonas helpon por starti ? Aŭ por uzi etendadon ? Usu la Didaktikojn !
PaulR
Message par PaulR »
Here's a simple effect:
Add text in a suitable font but click 'Transform to Selection' (I used VAG rounded font size 30)
Do Selection->Expand (here I chose a value of 4)
Do Edit->Stroke & Fill and apply a stroke effect (I chose medium grey thickness 1)
Choose Filter->Sylize->Contour 3D and use the default white and black, width 5 opacity 70
To add a nice background glow do Filter->Stylize->Progressive Contour and use a medium blue, width 8 and select 'Outside'.
Easy!
PaulR
Message par PaulR »
Here's another example
PaulR
Message par PaulR »
This effect is popular with my daughter too!
Very fine PaulR,
You can find also some tutos for text effects on the web site of Bill :
http://frontpagesolutions.com/photofiltre/index.htm
(unreadable at this moment)
I did this example too :
Note that :
- dégradé means gradient
- gravure = engraving
I hadn't try with BumpMap plugin, but i think it would be useful too.
PaulR
Message par PaulR »
The graphic for this tutorial can be found on my website at http://www.artefact-rescue.co.uk
