Unsharpen mask filter
jesito
Version de PhotoFiltre : 6.2.6
Système d'exploitation : XP et Linux
Processeur : Pentium Mobile 1,5 Ghz
Mémoire RAM : 1M
Message par jesito »
Hello!
I'd appreciate very much if someone could point me to any "unsharpen mask " kind of filter, to process digital pictures.
Thanks in advance.
Jes.
Hi jesito,
I'm surprised by your question.
Opposite of sharpen, in my lexical tools, is soften.
Two ways are available to soften a picture (native PF6 tools) :
- Menu Filter / Soften
- Menu Filter / Relief / Soften relief
Any mask cann't solve such a request, in my mind.
All the plugins compatible with PF6 are downloadable on the official site.
jesito
Mémoire RAM : 1M
Hi Tom:
Many thanks for answering.
In the photography terms, "Unsharpen mask" is not related to the "mask" concept in photofilter. Since most of SLR cameras have a filter in front of the CCD sensor, the pictures as taken from the camera, are a little "softened" and need to be "sharpened", (a common practice that is recommended by most of the camera manufacturers, like Canon for instance). You don't get the real sharpness from a picture until you apply what is called "unsharpen mask" on some picture retouching plugins, "low pass filter" on some others, or "intelligent sharpening". I belive this is referred more to the concept that to the real fact of having a "mask" to "sharpen", (I agree with you, this should be an algorithm not a mask in the Photofilter concept).
Here you can get a better description on this topic:
http://www.scantips.com/simple6.html
http://www.mic-d.com/java/digitalimagin ... index.html
The last one describes the algorithm and has an embedded java interpreter, so you can experiment with the resulting effects of this so called "unsharpen mask" algorithm.
Best regards,
Jes.
Hi jesito!
Suggestion: try the PhotoFiltre Studio version (30 days free) with the 8bf plugin named Blur and Sharpen FF plug-ins. Some comments and download link here: http://www.aim-dtp.net/aim/photoshop/v5 ... actory.htm
jesito
Mémoire RAM : 1M
Corwin13 a écrit :Hi jesito!
It looks like it's the way... Thanks!
I'll try it.
Best regards,
Jes.
Ok, it seams clearer, :)
thanks for these very interresting links.
In fact, an Unsharp Mask do exactly the opposite of what his name suggests. :shock: :shock: :shock:
I didn't know this lexical wonder. :roll:
So, i think you want enhance, increase and control a sharpen effect.
- in PF6 freeware, you can find 4 tools in Menu Filter : Sharpen. But i think you've found it.
- However you are perhaps not acquainted with Menu Edition / Fade
This tool can be applied after quite all filters, and offers asset of direct view on the whole workspace.
This is a very usefull function.
- in PF Studio release (efficient shareware for a cheap price) you can use some 8BF filters like Clarity from Xero web site (freeware) :
http://www.xero-graphics.co.uk/freeware.htm
A very powerful tool.
I hope it answer your request. :)
jimclatfelter
Système d'exploitation : Windows Vista
Processeur : AMD Athlon X2
Blur-Sharp
Message par jimclatfelter »
R,G,B: ctl(1)<0 ?
(cnv(1,1,1,1,1,1,1,1,1,9) * abs(ctl(1)) + c * (100+ctl(1)))/100 :
(cnv(-1,-1,-1,-1,16,-1,-1,-1,-1,8) * ctl(1) + c * (100-ctl(1)))/100
I use this formula for Focus in my 8bf plugins. If Antonio wants to use it in Photofiltre, it's fine with me. It works with a single slider set at zero to begin with. It's range is -100 for full Blur and +100 for full Sharpen. The Blur and Sharpen are just like the PFS buttons. Any setting above zero will sharpen gradually. Settings below zero will blur gradually.
The c in the formula could be src(x,y,z) instead. It stands for the original unblurred or unsharpened pixel.
The slider code is: ctl(1): "Focus ", range=(-100,100), val=0
I wouldn't mind having a button to call up a Focus slider instead of the Blur and Sharpen buttons. This way there would be no need to Fade the result.
This is just a suggestion. It took me a long time to get the formula figured out, even though its very simple. If you want it, it's yours.
I'm working on a new unsharp mask function with dynamic matrxi convolution, i will compare results :wink:
You can try the beta 9. In the filter Reinforce (unsharp mask) i use a dynamic laplace matrix. The result is good but very slow with high radius values
http://www.photofiltre-studio.com/tmp/pfs810.zip
