The nozzle files are 32 bit png files, but saving a png file in PFS creates 24 bit files. Can we create new nozzles with PFS?
I made a png file of photo corners. You can see it at
http://8bf.net/corners.png
Does it need to be 32 bits to work as a nozzle?[/url]
New Nozzles
- Habitué(e)|Habitué|Habituée
- Système d'exploitation : Windows Vista
- Processeur : AMD Athlon X2
- Mémoire RAM : 4 GB
