Thank you, I didn't understand yllei's questionTom a écrit :Oui yllei,
il s'agit d'un filtre 8BF de la série Esthétiques. Le lien se trouve sur le forum en recherchant avec "contour AND lumineux" et tu trouveras aussi d'autres façons de travailler les contours.
Contour artistique & Modes de fusion => PF Studio
Jitkara
Re: Blend modes - eponymous ???
Hi Marga,Marga a écrit : 7.3.0 .... but never saw a plugin BLEND modes..... what means eponymous
- eponymous means "which has the same name" : the official web site of PF Studio has the same name as the software.
- great news on the 7.3.0 release : the blending modes
When you duplicate the background layer and the layer tool is activated, on the bottom of the tools desk you can see a choices box with Mode as name.
Clic on the triangle and you can see 12 different modes to blend the active layer with which is below it.
To see a quick effect look at this link :
http://frontpagesolutions.com/t/001/index.htm
Have a fine day too, Marga
- Mémoire RAM : 512 Mo
yllei
- Système d'exploitation : xp
- Processeur : pentium 3 1ghz
- Mémoire RAM : 384 mo
Marga
- Habitué(e)|Habitué|Habituée
- Version de PhotoFiltre : PF and PFS
- Système d'exploitation : W7
- Mémoire RAM : 3
Blend modes
Wauw... that's wonderful. I recently installed installed 7.3.0 and did not yet notice that hte blend-modi were there. Exactly what I missed after using PSP for many years.
Thank yoy for explaning.
Greetings,
Greetings,
