PhotoFiltre Studio 7.3
Try the last beta 10 :wink:
carlo taradel
Version de PhotoFiltre : PF-PFS
Système d'exploitation : win XP pro- ubuntu_ breeze
Processeur : recycled from waste bin
Mémoire RAM : 1026
Message par carlo taradel »
:?: Bill did you try my advice :?:
I mean instead than duplicate the LAYER ,blurring it (or do anything else to it like using filter or colour corretion tools)and then blending
:idea: Duplicate the IMAGE correct the duplicate in the way you need and, only when you finish any kind of correction/manipolation, paste the DUPLICATE IMAGE on the original (=add as new layer on the original)... and then blend it :idea:
I don't know why but often in this way i get much better results
...I didn't try beta10 yet maybe it will solve also this kind of problems 8)
Bill
Version de PhotoFiltre : Free and Studio
Système d'exploitation : Coffee
Processeur : God Given Brain
Mémoire RAM : Not as well as when I was younger
Message par Bill »
Antonio:
Yes I tried it last night. Great improvement. :D Merci
Carlo:
One thing I've learned by being a Wise Old Sage is there is more than one way to skin a cat when it comes to Graphics Software.
Most of the time there is more than one way to do something or create a certain effect. A lot of times it has to do with a persons way that they work and nothing more. In the case of some of my tutorials I've done for the past 11 years I will do things for no other reason than to showcase a function the program may have that folks would otherwise not even know about.
Just look at transparency in PhotoFiltre Studio! You can create a mask, you can create and then paste an aplha layer, you can use the Layer Gradient Tool, you can use the eraser tool, you can make selections and there is probably something else that somebody will tell us about that I don't know or forgot. Which way is best? You can debate that one I won't touch it with a 10 foot pole.
Now onto your suggestion, I really did not see how it applied to my tutorial since the Correction was the blur and screen. You State:
That is exactly what I did. I corrected the image, by using a blurred screen. Now I could just as easily have used Gama Correction and Brightness and Contrast to correct the image but I was doing nothing more than presenting a different way of correcting the image to folks who may not be aware of that technique and also introducing some folks for the very 1st time to the power of the Screen Blend mode.
carlo taradel
Mémoire RAM : 1026
:oops: well...i suppose i had to check better before writing...i didn't notice that in my Preference Setting the 8bf were on RGBA mode, and since layers don't support that mode most of the filters didn't work well on layers...and this add more fuel to my impression that, when possible, was better do all manipolations on images ..excuse me please!
if i understund well you
1open the image
2 duplicate the layer ....and so on
my idea was to
1 open the image
2 duplicate the image ....and so on
result is exactly the same skinned cat,...but there is a difference,it is a way to skin a cat that works also to skin a horse or a apple:
Still i think than the work on a (duplicate) image is more easy and flexible than the work on a (duplicate) layer, ... again you are right this is not directly connetted with your tutorial ,as it is , but could allow more flexibility to apply variants with success...and Best tutorias to me are the one that could be used as starting point and customized ,and in those occasions flexibility is highly welcomed.
sorry i'm going out of topic... and more i'm stepping in the battleground of giants...i'm going back to the new beta...and again Bill thank you for your tutorials because they help me to discover a lot of hidden and very useful features of PFS :!:
jimclatfelter
Système d'exploitation : Windows Vista
Processeur : AMD Athlon X2
Message par jimclatfelter »
Where is beta release 10?
I'd like to try it.
Bill a écrit :Here is my 1st Tutorial Salvage an Under Exposed Image.
Hi Bill,
I appreciate greatly this tuto and use it very often.
I regret that it is not translated in french : i'm sure that many folks would find it very usefull.
Could you think also or find some few minutes to add on your site a link forward your french pages, translated by Sterenn ? :wink: :wink:
Regularly some people ask for find them.
With pleasure to read you soon.
