can you tell me where i can setup corner's ratio in PFS 10.4.0?
thx
PhotoFiltre 6.5.0 with Windows 7 64 bit
cesarf
- Version de PhotoFiltre : 11.6.1
- Système d'exploitation : Win10/11
- Processeur : Intel i3-6100 @3.70 GHz
- Mémoire RAM : 16Gb
Re: PhotoFiltre 6.5.0 with Windows 7 64 bit
Hi cesarf,
did you open menu Selection / Rounded rectangle ?
But there is a better tip for a full adjustable one.
daavidfischer
So does this mean that I have to use the studio version in Windows 7? I am facing the same issues listed above; I am a novice user so I am not able to find a solution myself. I am using Windows 7 home edition 64bit.
Hi,
The title is not according with the version described in the first post.
In the PhotoFiltre 7 version, you can find, for this point, the same setup as Studio.
The news for the 3 versions : http://www.photofiltre-studio.com/news-en.htm
