filtre o plugin
Marisa
filtre o plugin
Message par Marisa »
Is there a filter or a plugin that gives the possibility to save the effects of the writings in PFI format so that those who follow us can also use them? Thank you
Re: filtre o plugin
no, only effects in the Text fonction ara saved (color, shadow, pattern, ...)
Marisa
Re: filtre o plugin
It's a shame, in my opinion these functions are very useful
Re: filtre o plugin
N'oubliez pas qu'avec LibreOffice il est possible d'avoir pas mal d'effet de texte, ensuite il suffit de faire un copier/coller dans PhotoFiltre
Marisa
Re: filtre o plugin
Yes, but it would be nice to do it directly from photofiltre, such as "photoshop" or other graphics programs :)
