Folder explorer takes too much space! how to unview it in v7
finder77
Version de PhotoFiltre : 7.2.1
Processeur : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz 1.50 GHz
Mémoire RAM : 6 GB
Message par finder77 »
[en anglais]
Hi all. I am using PhotoFiltre 7.2.1. It is wonderful! It is VERY useful!
It is freeware. I am reluctant to download a newer version that is not free.
What I detest though is that the folder exploration panel takes up much too much space on the screen, leaving less space to see open images that I might work on. But I see no way to suppress the folder exploration panel. I don't think this version uses a .ini file. I think I would be willing to download an earlier version, perhaps version 6, if that is the only way to rid the problem I have. I don't think version 6 had the panel in question (not sure). And I don't require all the latest newer functions -- only the basics. Of course I want to always have the option to return to v7.2.1 if I should decide I need it. I am looking in my files for installers and how I got v7.2.1. I find I have only an installer named "setup-en-653" so I assume that is version 6.5.3 and so I have no recollection whatsoever how it is that my version now installed and in use is 7.2.1! (And I do not understand why it is freeware.)
I can live with the folder exploration panel but I dislike it. I hope for some advice. Thank you, merci.
Re: Folder explorer takes too much space! how to unview it i
Hi, this command is a swing :
- one click on his icon => open
- another click on the icon => close
Or Ctrl + E
or menu : Tools / Image exporer.
Have a good week-end. :)
finder77
Mémoire RAM : 6 GB
Yes, thank you ever so much :D
