Hello everybody from Hungary!
How can one layer ("holes") to prepare,
(For example, a small square)
which shows through every layer, but the hole location is not fixed?
(Actually a hole image ...)
So: all layers hole in the place, but only have to move one layer.
(or at least make the background transparent in that place ...)
it is possible?
Thank you in advance for your answer.
(I do not speak English well,
Thank you to the google translator ....)
layer transparency in another layer also
- Version de PhotoFiltre : 7.2.1.
- Processeur : Intel I3
- Mémoire RAM : 8GB
Re: layer transparency in another layer also
i don't understand exactelly, did you have a sample ?
you can add a blank layer and delete a square part to create a hole
- Mémoire RAM : 8GB
HELLO!
I thought
absolute transparency on every layers.
but at least on the background.
(how to upload a picture?)
I thought
